EOS Utility 3.16.11 won't install on MacBook M4
brianwpiper
I have a Canon EOS 250D / Rebel SL3 DSLR that I had hooked up to my PC as a webcam using the EOS Utility and it worked great. I recently upgraded to a 2025 MacBook air with M4 and am trying to get the EOS Utility 3.16.11 to install and it extracts the files, has me select the country and, when I hit next...nothing happens.
I updated the firmware on my camera, restarted the Mac, and nothing seems to work. Any ideas?
10 REPLIES 10
brianwpiper
I also tried 3.15.20 with the same outcome...
Hello.
The EOS Utility is not used to live stream. You would need to use the EOS Webcam Utility Pro, which can be found at https://canon.us/ewu
The current version for macOS is 2.3d
brianwpiper
Awesome, thank you! I installed the utility and my camera still doesn't show up as an option in any webcam tool and I can't see the camera in the utility the way I could previously.
brianwpiper
Hmm...do I have to pay for a subscription now to use my camera as a webcam?
There is a paid subscription option for advanced features, but you can use the basic features for free. It's been this way for over two years.
Learn more at: https://canon.us/3M9lOXl
FEATURE FREE SUBSCRIPTION
Default Scene
User Custom Scenes MULTIPLE
Multiple Camera Connection UP TO 5
Wireless Connection 1 CONNECTION
Stream to Multiple Channels
UVC Video Input Support Including Capture Cards
Camera Setting Control Manual CONTROL FROM UI
Global Image Adjustment
Scene Layout Editing
HD 720 Support (Digital Upscale)
Full HD 1080 Support (Digital Upscale)
Up to 60fps Support
Control Content by Channel
Video Input Layout Option to Fill/Fit Screen
Flip/Rotate/Resize Video Input
Crop Video Input
Water Mark Insertion - JPEG, JPG, PNG (Alpha Channel Support for PNG)
Crossfade Transition Between Scene
Hot Key Setting
Window Capture
Startup Scene Configuration
New Version Reminder/Install
Dark Mode
Global Hot Key Support
Full Screen Sharing
Canon Camera UVC Input Support One Connection
Text Overlay
Dynamic Driver*1
Elgato Stream Deck Support*2
Template Support
Language Support (Spanish, Portuguese, French)
Battery Info Display
Background Blur/Removal
*1 Only supported on Windows
*2 Tested with the Stream Deck Mini, Stream Deck Neo, Stream Deck 12, Stream Deck XL, and Stream Deck (All Stream Deck Devices were tested with Stream Deck App 6.6.1)
brianwpiper
Excellent, thanks! I still don't see any way to add my camera or select it to use. It doesn't show up in any of my system settings and I don't see any way to add it within the utility
Greetings brianwpiper,
If the EOS Webcam Utility is not recognizing your EOS Rebel SL3 camera, then let's check the camera's Wi-Fi function prior to connecting the camera to your computer with a USB cable. When the Wi-Fi function is enabled, even when it is not in use, it will disable the camera's USB port. After disabling the camera's Wi-Fi function, proceed to connect the camera to your computer with the USB cable. If the EOS Webcam Utility is still unable to recognize the camera, then let's check to see if the computer can detect the camera. Open Apple's Image Capture app that is pre-installed on your computer. If the app detects the camera, then let's quit the Image Capture app and check and quit any other app that may be running that is attempting to communicate with the camera. In case the Image Capture app is unable to see the camera, then let's test a different USB cable, or check to see if a different computer is able to recognize the camera. This would help to determine if there is an issue with the cable you are using or something on the computer that is preventing the camera from communicating with the computer.
Thanks so much, NatalyaP! Very helpful. My wi-fi settings are off on the camera. I was able to access my camera through Image Capture and see the photos that I have on the camera. I was also able to open remote live view on the Canon app and see my video! YAY!!
The problem is that the camera doesn't show up as a camera option on Zoom or Google Meet. How do I get it to be recognized by those applications?
Thanks again and sorry for the delayed response, I was out of the country and didn't have access to my camera setup.
brianwpiper
I'm using Sequoia on my Mac if that makes a difference.
Thanks!
