EOS Utility .Net Framework warning
JMcKinnon1966
When I connect my eos rebel t6 and try to start eos utility version 3 I get a Net. Framework error message. What do I do?
13 REPLIES 13
The repair tool didn't work
Anonymous
Not applicable
"Yes and Yes"
What is the error message that you are getting when you start EOS Utility?
If you are seeing a dialog box to install the .NET Framework when the error occurs, are you clicking yes to install it? Also, did you try to re-install the EOS Utility? Usually when a program installation requires .NET Framework, it will offer to download and install it for you, if you allow it.
I attempted to provide clear instructions.
If you are running windows 11, it includes .Net Framework v4.8.  Try running the repair tool above. *(you are not running windows 11)
If you are running an earlier version of windows, see the following:
The second link I provided allows you to install .Net
Looks like you are being prompted to install it when running the App as well.  The app will not run without it.
If installing .Net 4.7.1 or later does not resolve the application start issue, you have another problem as Waddizzle mentions.
So, have you installed it? Or does the installation not work?
