EOS Utility Constantly Drops Wireless Connection to Canon t7i
idcampbell
I have a t7i and EOS utility v3 and the software has started to suddenly disconnect after 1 or two shots during remote shoot mode as well as during image transfer. It should be noted the problem only seems to occur when using my wireless router. If I use the t7i as an access point the problem does not occur. Both the camera and network router have the latest firmware versions.
I performed a factory reset on my router and this appears to have resovled the problem.
7 REPLIES 7
alexpilion
Enthusiast
It could be an interference issue, apart from your wifi do you see any new network there, like for example the one of from a neighbour?
In case there are more you can try to set the wifi-channel manually to avoid the overlapping.
If you look for the wifi settings on your router/modem search for a channel and instead of Auto try 13, if available, or 10. Generally devices using automatic work with channels 1 and 5 so using these should avoid the issue.
If not you can find further info about checking wifi network overlapping at your place from this page: https://www.howtogeek.com/197268/how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating...
The best way to do it is with mobile so you can verify in many different places of your home/studio, including your desk and close to the tripod.
I hope this help.
Waddizzle
It is not clear what it is that you are connecting to, which has started to suddenly disconnect.  Is it a phone, computer, tablet?
The disconnect occurs regardless of the device to which I'm connected (tried both tablet and PC for example).
It makes a major difference.  Those are different devices, which run different apps to connect to the camera.  What OS is running on the tablet and computer?  That makes a difference, too.
Let's pick one.  Let's go with a Windows 10 compuer, running the Intel chipset.  Have you tried using a USB cable between the camera and the Windows PC?
I'm not convinced it a DSLR/tablet/PC issue. The tablet and PCs are both running Windows 10. When I use my home wifi the EOS utility drops connectivity after 20 or so seconds. If I use the DSLR as a wifi access point the connection to either the PC or tablet are solid.
In that case, I suggest that you contact Canon Support for assistance.
