08-21-2022 02:25 PM
Hi, I downloaded EOS Utility which came with EOS Utility 3 but not EOS Utility 2. That's the message I get when I try to connect my 70D:
I tried to download it separately but it still doesn't appear anywhere in my Programme Files. What should I do? I need it to download a flat-like profile.
08-22-2022 12:06 PM
You do not want to download the latest version of the EOSU3 installer if you want to get EOSU2.
You need to download version 3.13.20 or earlier. That version will install EOSU3 along with EOSU2. The Canon support site used to explain that but the new format has removed a lot of explanatory material in the apparent interest of uniformity.
08-21-2022 05:55 PM
What Operating System are you running? What version of the EOS Utility 3 did you install?
The most current versions of the EOS Utility 3 for Windows 10 will also install EOS Utility 2 at the same time. The latest version is 3.15.0.
08-21-2022 07:49 PM
Go here: Canon Support for EOS 70D | Canon U.S.A., Inc.
Download EOSU 3.13.20. It will also install EOSU2. Any later version of EOSU3 will not install version 2 along with it.
08-22-2022 11:20 AM - edited 08-22-2022 11:35 AM
You can also install EU 2 separately if EU 3 is already installed. They can coexist just fine, and the correct version should open for the camera you connect.
08-22-2022 11:27 AM
I uninstalled what I had before and downloaded the installer from the linked page. Still, no Utility 2. I'm running Windows 10.
08-22-2022 11:32 AM
Did you download 3.13.20 (not 3.15)?
08-22-2022 11:34 AM
I'm running Windows 10. I installed the latest version of EOS Utility from the official page. Utility 3 came with it and it's the latest version as well. Utility 2 doesn't even appear on the list of the installer.
08-22-2022 12:06 PM
08-22-2022 11:25 PM
Hi John, I just wanted to say I was having this same exact issue and you helped me a lot, thank you so much!
08-23-2022 05:49 AM
Glad I could help.
