DPP4 Quick check, move to recycle bin, grayed out?
robgilmo
I am running Windows 10, the option to move to recycle bin is grayed out in quick check, any ideas?Screenshot (49).png
2 REPLIES 2
Ray-uk
Whiz
Mine does the same so that is how it is meant to work. I never use quick check so had not noticed this.
If you right click on the large image rather than the thumbnail I see you get an option to mark the image as rejected, does this mark it for deletion, I haven't tried.
I think thats the only way to do it, mark as rejected then return to thumbnail screen and delete as a batch, its quite easy once you do it once or twice, and also gives you a second chance if you change your mind.
Friends and Family
