03-15-2023 01:28 PM - last edited on 03-15-2023 01:35 PM by Danny
Why is it in DOP4 I have no adjustments in White balance and I am unable to use the drop-down shot settings? Thanks for any help.
03-15-2023 10:39 PM
Hello, Larry!
Are you editing Raw or JPG? DPP is primarily a Canon Raw editor. Usually, when some menu items are unusable it is because you are trying to edit JPG files.
Newton
03-15-2023 10:39 PM
Hello, Larry!
Newton
03-16-2023 07:46 AM
Thanks. Obviously I'm learning
03-16-2023 02:15 PM - edited 03-16-2023 02:17 PM
@Larry13 wrote:Thanks. Obviously I'm learning.
Yes sir, just like we all were, and still are for that matter 🙂
A lot of us here only shoot Raw because it gives us more control over the final image. But that doesn't mean it's right for you. I would suggest setting up your camera to shoot both (Raw+JPG) on a few sessions to see which format you prefer or need. If you have picture styles and other settings in the camera set up properly, JPG might be all you need. But if you use Raw, you can change those settings in DPP after the shoot.
Newton
