04-18-2023 11:32 PM - last edited on 04-19-2023 10:38 AM by Danny
When I use cannons d pp4 and I checked the autofocus squares sometimes some are red other times with the same auto focus setting they're all black can anybody explain that to me. I have a 77D 45 squares.
04-19-2023 08:01 AM
Red squares indicate the points that were in focus. Black shows all the focus points. You can toggle between all or just in focus.
If you are in AI Servo focus isn't always locked, so no red squares appear.
04-20-2023 06:02 AM
The only time Canon’s DPP4 displays locked AF points is when the AF system in the camera is active when the shutter was fired.
For example, if you use BBF and release the BBF when shutter is fired, no AF points will be recorded as active, even though one or more may have had a focus lock prior to you releasing the BBF button.
Try this. Take a photo of a static subject while keeping BBF pressed. Try it again with the BBF button released. The first photo will display active AF points, while the second photo will not.
04-19-2023 08:01 AM
04-20-2023 06:02 AM
04-20-2023 10:45 AM
Thanks it helped
