Canon Connect app GPS update rate?
vantage
Enthusiast
Enthusiast
Hi All,
Does anyone know the Canon Connect app GPS update rate? In other words, how often does it update the camera with the location your shooting from? I'm already aware that general GPS receivers update position once/second. I recently did a walking tour in wide open spaces ( so no obstructions), took 14 photos in different locations and the location of all the photographs was exactly the same.
Camera: R5 running firmware version 2.0.0
R5 showed Bluetooth and GPS active
Canon Connect app version 3.2.0.20, build 1391,app shows Status: Sending location info to camera, GPS via mobile: Available, Location information: Can be used
TIA
44 REPLIES 44
vantage
Enthusiast
Enthusiast
@Mogster2k said
"There are long threads over at DP Review forum about this same issue with the new R5ii. "
Please provide a link to those threads. I searched for them to try and help those folks and couldn't find anything.
TIA
Here’s one. There are many others describing similar behavior.
https://www.dpreview.com/forums/threads/problem-with-r6-and-camera-connect-iphone-gps-tagging.466799...
Tbh I’ve given up on a fix now, I’m just disappointed the R6iii doesn’t have internal GPS. This behavior has been present through repeated updates of camera firmware and app. Canon is either unable to fix this feature or just doesn’t care enough about it to spend the time on it.
vantage
Enthusiast
Enthusiast
@Mogster2K
What are the power savings settings on your camera?
I’ve tried with everything disabled in the power saving menu. It makes no difference. Routinely I have auto power off set to 5 mins. Viewfinder 1 min. Everything else disabled. I don’t like the lcd screen dimming.
Powerkey
In case anyone else is having trouble with Smartphone GPS functions from the Canon Camera app, I recently found a solution that does work.
I have an old iPhone 8 Pro that was collecting dust. I updated the OS (16.7.15) and downloaded an older version of the Canon Camera Connect app (3.2.40.36) and connected that to my R5 via Bluetooth. Location Services are set to "While Using" and I am leaving the phone unlocked. The phone itself does not have a SIM, which I recently discovered is not required for GPS functionality.
I have been out 3 times and all photos are properly tagged with the current location.
