Camera Connect - “No card in camera”
Jennaterborg
Hello,
I know this app is super glitchy and have rebooted, re-installed several times now and am still getting the same error message.  I tried on both my ipad and my iPhone, every time I connect and try to access my photos I get the error “No Card in Camera”…when there clearly is a card in the camera.  Any advice would be appreciated!
4 REPLIES 4
Lets start with the basics,
Camera Model is?
Brand and type of card you are using?
iPhone and iPAD model(s) are?
Running which version(s) of iOS?
Does Camera Connect make a successful connection with the camera?  Meaning can you control it but not download images, or its not connecting at all?
friedricebryce
Had the same issue with my M50 mkII. Tried all the basics - reset wireless settings, redownload the app, format SD card, different SD cards...
The fix? Take the battery out and put it back in.
Frustrating to waste half an hour messing around with it and going through the hassle of reconnecting and resetting everything, but thankfully it's working now. Really wish Canon would invest just a tiny bit more money into their app.
It worked!
I had the same issue - the camera ( m50mk2) shows it has the capacity to click 9999 images, and the app shows " no sd card in camera".
as soon as I take the battery out and put it back, it shows it has the capacity to click 6000+ images and the app also works now.
Waddizzle
The most common cause of memory card problems with entry and beginner level cameras is the use of incorrect memory cards.
The microSD cards are always the wrong choice.  The use of SDXC cards, 64GB or larger, can also cause errors.
