Cannot find EOS Rebel T7i Firmware
clynch
Your instruction keep leading me to the standard support page, but when I go there is no reference for Firmware and I have looked in ever sub area.  I want to connect it to my Android Phone
21 REPLIES 21
Hi there, and welcome to the Canon Community!
If you're ever confused and would rather speak with technical support one-on-one, call our team here in the USA at 800-OK-CANON (800-652-2666). You may find it beneficial to register your camera before calling. You can do that at canon.us/account.
I'm not a tech, but I wanted to take the time to walk you through the process because it can be a bit much.
You can't install firmware using a mobile device (phone or tablet), so you will not see it unless you're on a computer.
From a laptop or desktop, navigate to https://www.usa.canon.com/support/p/eos-rebel-t7i
  • On that page, tap "DOWNLOADS" in the top black bar (just above the photo of the T7i).
  • Expand the "Software & Drivers" section by tapping it.
  • The site will have detected your computer's Operating System. However, the firmware came out in 2020, before Windows 11 & the most current versions of macOS. That means you must change it manually to "macOS Catalina v10.15" if you're on macOS or "Windows 10" if you use Windows.
  • Just below the Operating System drop-down is another drop-down that says "Download Type." Change that to "Firmware"
  •  You will then see, at a minimum, the most current firmware file:Stephen_0-1709214128978.png
  • Tap the box above the gray download box, and it will activate and change to red, allowing you to download the file.
I've attached a PDF with the official update instructions once you have the file.
I sincerely hope this helps, but please, if you get stuck or need someone to walk you through this, give our team a call! They're available 9:00 AM - 9:00 PM Monday through Friday and 9:00 AM - 7:00PM on Saturday.
"WITH THIS KIND OF SUPPORT THIS WILL LIKELY BE THE LAST CANON PRODUCT I EVER BUY!!!!"
Why? You got a comprehensive reply from a Canon employee. You got several instructions and advice from folks that have no incentive to help. They just want to see you get what you wanted.
And, BTW, it is considered very rude to use all caps. You might keep that in mind next time you go off.
EOS 1DX and many lenses.
clynch
I am a tech person,  I have primarily worked in Fortune 100 Companies and spent 13 years at one of the big 3 Tech Companies.  For my own personal use I setup and maintain home automation, whole house automated lighting, home security, Garage Doors, Media Server connect to all computer and TV’s, and Automated HVAC and all including remote access to all of that and the computers and other misc. hardware.   I have directories full of downloaded drivers, manuals to maintain all of this stuff.  In all this I find my experience with Canons Support site as the worst I have had with anybody’s support site especially from a big company like Canon.  And then there is the armature support!
Canon should be doing much better for Support.  And I have heard that many of the Camera Companies are moving to Android or other similar OS’s to drive new Cameras, Canon, you really are going to need to support your product so much better!  For me this experience will be a big negative for buying any future Canon Photography Equipment.
Chuck Lynch
Just to reiterate, Chuck.
The Canon Community is hosted by Canon USA, but you have only interacted with one Canon employee so far, now two including myself. This forum is a place for Canon users like yourself to crowdsource ideas and troubleshooting. Canon only steps in if the Community cannot help. All of the Canon employees will have the title Community Manager, Moderator, or Product Expert, all other people you interact with are just enthusiasts who enjoy lending a hand.
In the future if you'd like direct support from Canon immediately, you will need to access your support options via the MY CANON ACCOUNT portal or by calling in. HERE is a direct link to the Community guidelines should you like to refresh on the rules and how the Community works.
Hope this helps!
What are you even talking about?
If you want to use the Android App, by all means, use the Android App. You'll find info on it HERE.
But you were saying you wanted the firmware update. For that, you need a computer.
If you're trying to tell me you keep your home lab up-to-date without a computer, you have far more patience than I do. Keeping my systems up-to-date is far easier using a computer with terminal access. 🤷
Chuck Lynch
It took me all of 30 seconds to find the firmware and another minute to post my response to you showing you where it is. That's good enough support for my needs.
“I have primarily worked in Fortune 100 Companies and spent 13 years at one of the big 3 Tech Companies.”
Kinda makes you wonder doesn’t it?
I love how people chime in here and don't have Clue!
From the Canons Firmware download for my Camera
Firmware Version 1.1.0 incorporates the following enhancement:
1. Enables NFC connection with smartphones running Android 10 operating system.
*For Android running v6.0 or later, use Camera Connect v2.7.10 or later.
*For Android running v5.0 or older, use a connection method other than NFC.
Plus I also don't have the previous Firmware Update 1.0.2 that should be included in this latest included 2 patches to protect your phone from vulnerabilities in the original cameras software.
Software Vulnerabilities can be a really bad thing!!
Firmware updates are inclusive. "Up to" means 1.02 or lower.
Ebiggs1 and jrhoffman75 thanks you so much for your personal expert critique
At least my problems where with a  site and a company and I didn’t make it personal!
I guess my biggest mistake was thinking Canon was a competent company,
I am an Expert SQL Programer / Designer
This problem is being caused by likely one record in a database that should take like 2 minutes max to fix, but it appears to me Canon doesn’t care enough about support to fix it and instead has make the user find the secret way / fix around it etc.   Wasting way more support users time multiplied by how many users than run across the problem.  Like I said I did make the mistake of thinking Canon  care about support and now I think that statement is not true!
They do know about this problem!
