GP-E2 on EOS 7D: Camera won't recognize GPS
Aaplmike
Hello. I bought a GP-E2 for my Canon 7D in the hope of capturing and attaching coordinates to the meta data in the photos I take.
I've attached the unit to the camera via a USB cable, but when I go to the "GPS Device Settings" menu, it says, "This menu cannot be displayed. GPS unit is not connected."
Well, I obviously have the unit attached and powered on. Since this is a 7D, the hotshoe connection won't work with the GP-E2, hence the USB cable, as described in both the camera and GP-E2 manuals.
I've also tried to attach the GP-E2 to the USB port on the WFT-E5A, but the WFT Settings -> USB device connec. option tells it's an "Incompatible USB device". Huh? It's a friggin' Canon GP-E2!
I've tried several USB cables, and I'm wondering what else could be wrong. The GP-E2 does show up on my computer as a Canon GP-E2 when I connect it, so I believe that means the cable must be working.
Any ideas?
10 REPLIES 10
Peter
7D didn't have any support for GP-E2 when it was released. Support added with firmware version 2.0.0. Is your 7D updated?
jrhoffman75
Do you have the latest firmware for your 7D? (Or at least 2.0.0)
Aaplmike
Thanks. Yes, I have v2.0.6 installed on the camera. I wonder if the WFT-E5A and GP-E2 have updateable firmware.
2.0.2 is the latest for GP-E2. 1.0.7 for WFT-E5A
Aaplmike
I’ve upgraded the GP-02 from 1.0.8 to 2.0.2. Still isn’t recognized by either the 7D or the WFT. I’ll just return it. Disappointing as it’s really the only Canon-branded gps that would work. So far haven’t found any 3D party alternatives either.
Waddizzle
I dunno.  Try connecting and turning on the GPS before you turn on the camera.
Is it acting like a logger? You could get a third party software that writes to the metadata.
Apps to Geotag Photos (havecamerawilltravel.com)
John and Peter certainly nailed it with FW recommendations.  The system map shows GPS support via the WFT-E5A using USB.  I'd call Canon support to see if they can offer any suggestions.  He appears to have the pre-reqs met.
Peter
I have GP-E2 and 7D, but no cable. I ordered one June 27.
