01-25-2026
01:36 AM
09:40 AM
I want to replace the eyecup with a long eyecup. Does the R6 Mark III use the same shape and connection points as the R6 and R6 Mark II?
If they are compatible; how is the eyecup removed from the R6 Mark III, as it doesn't appear to have the tiny screws to hold it in place.
01-25-2026 01:52 PM
The screws are hidden under little covers that are held on by sticky tape.
It has been reported on line that the JJC extended eyecup does work with the R6MIII.
03-24-2026 12:11 PM
They pop off using a pin or sewing needle.
01-25-2026 01:52 PM
03-24-2026 11:58 AM
Any idea about how to remove these nasty little covers held on by sticky tape appreciated - missing the JJC extended eyecup I´d used at my R62.
Thank´s in advance
Norbert
03-24-2026 12:11 PM
03-24-2026 12:18 PM
Thank´s John, will try out!
Norbert
03-24-2026 01:28 PM
Succeeded, thank´s again. These cap´s are indeed increadibly thin, other than they appear they are.
Norbert
04-03-2026 09:01 PM
And it's a bonus that JCC supplies four screws with the new eyecup. I only needed two but they obviously know what a pain it is to remove the originals.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
