07-07-2020 04:56 PM - last edited on 12-30-2022 09:47 AM by Danny
This isn't a Canon-specific issue but does affect my video recording setup using my 70D.
I have an external lavalier, wired mic. On both my phone and my camera I have the same issue:
Running on battery - all good works and sounds great.
Running on AC power - very loud buzz (AC line noise I assume)
Any ideas or reccomendations on how to filter that out? A setting or a separate device like an in-line filter?
I sure can't be the only one using AC power and a mic.
Thanks!
07-07-2020 06:08 PM
You have a problem with both your phone and your camera using the microphone. I suggest that you consult the manufacturer of your lavalier microphone. It seems that you may not have the proper microphone, or the wiring connections are not being properly executed.
07-07-2020 06:15 PM
Not exactly. Works fine on both using DC power. Only happens using AC.
07-07-2020 06:24 PM
@Mandi wrote:Not exactly. Works fine on both using DC power. Only happens using AC.
My friend, you have a microphone problem. Contact the microphone manufacturer. You may not be connecting it properly.
07-07-2020 09:10 PM
Are you not familiar with the common issue of AC line noise interfering with sound systems? Lucky
07-08-2020 05:42 AM
Wadizzle is right, this is a microphone problem either relating to a poorly designed mic or a connection problem most likely causing a ground loop. There is a slight chance it could be faulty power supply but this very unlikely.
07-08-2020 10:07 AM
If the "reverse the AC plug" trick does not work, than the answer is don't use AC, keep to the batteries.
07-08-2020 01:37 PM
"reverse the AC plug trick"
What does that mean?
07-08-2020 01:47 PM
@Mandi wrote:"reverse the AC plug trick"
If your AC plug is not polarized, simply pull it out and reverse it in the socket. Sometimes it matters which end the hot or neutral connect to.
07-08-2020 10:11 AM
@Mandi wrote:Are you not familiar with the common issue of AC line noise interfering with sound systems? Lucky
Most of us don't do much video.
Of those that do, most use the internal microphone.
Of those that use external microphones, they keep with battery power.
So, yes, you are one of the very few who use AC power with an external microphone with a DSLR.
