01-06-2023
12:35 PM
12:44 PM
my Canon 80D cannot take pictures with a C1-type shutter cable. When I click the remote shutter button, it does focus adjustments (like a half-press effect) but never releases the shutter.
I've tried with multiple cables and to be sure it's less to do with the cable, I got a brand new one from Edelkrone at BH, yet no luck.
I've made a recording at https://youtube.com/shorts/aVofGN7vbnA?feature=share
Any idea how to fix this? Let me know. Thanks!
Camera: Canon 80D
Shutter Release Cable:
Remote shutter:
[Commercial links removed per forum policy and replaced with screenshots to facilitate discussion.]
01-06-2023 01:55 PM
Are you sure camera is achieving focus? Set lens at MF and see what happens.
01-06-2023 02:00 PM
Thanks for your response. The video I posted was made with manual focus. When in manual focus, it just removes some details from display but do not trigger shutter, just like doing a half press.
01-06-2023 02:14 PM
I just looked at the video again. It says ni card in camera. You probably have that protection set in the Menu.
01-06-2023 02:35 PM
No, I've not enabled that protection, verified in the settings. Btw, I could trigger from shutter button on camera.
01-06-2023 02:39 PM
Since the camera shutter button works it looks like all is pointing towards either a defective remote or some other setting on the remote that needs to be changed.
01-06-2023 04:05 PM
Yea, looks like some settings got messed up. I did reset all settings though, yet the same behavior. I've used different cables, different remotes nothing helps.
It did work a couple of weeks back when I kept reinserting cable but the same trick isn't helping anymore.
I thought it must be something to do with the cable, so got brand new from Edelkrone but is not helping either.
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
