09-10-2022 01:56 PM
I have had my 1DsMKII for ever. Now when I plug the batteries into the NC-E2 Charger only the "Refresh" yellow lamp comes on , sometimes flashing, sometimes on solid, and the batteries do NOT charge.
Am I missing something?
"Charge" light never comes on.
09-10-2022 03:08 PM
The Refresh cycle takes about 8-9 hours. No charging will take place until the Refresh cycle has completed.
Have you waited 8-9 hours for the cycle the complete?
09-10-2022 03:08 PM
09-11-2022 10:19 AM
YES I have and the "Charge" light never appears. 2 batteries connected.
What is so unusual is that the copy of the Instruction Manual you post above is NOT included in original "Owners Manual"
Thanks!
09-11-2022 01:33 PM
Gentlemen!!!
I am a total IDIOT!!!!!!
The "Power" light was lit but the charger was NOT plugged in!!!!!!!!!!!
Feel free to call me that!!!
Thanks!
Dan
09-10-2022 03:12 PM
Of course, you have either a bad battery or a bad charger. Here’s some food for thought.
I ran into a similar issue with my 1D Mark IV. My battery would not always charge. I only use it indoors at home, so I figured an AC adapter would work around the problem. But, the cost of AC adapter was enough to make me pause.
So, I bought a used 1Ds Mark III for $100 more than the cost of the AC adapter alone. The camera came with a battery, a charger, AND the AC adapter.
09-11-2022 10:21 AM
Read above ^^^^^..Thanks!
This body makes some super files but the longevity appears to be limited.
That is fine! I will just use another Canon body. I have a few.
Thanks for your input!
