12-09-2012 11:39 AM
12-10-2012 01:45 AM
Can you post a sample audio clip? Is the audio from the Rode mic coming in at all? or just the buzzing?
If there's audio but with an ambient buzzing, it could be interference that the connection/cable between the mic and camera picks up on, or maybe the plug isn't inserted fully.
12-11-2012 09:45 AM
@paulchenier wrote:While using a RODE external microphone I get a buzzing noise
Hi paulchenier! In order for the community to assist you better we will need a little more information such as the model of your Canon product, when you’re having the problem, the type of microphone you’re using (powered, unpowered, powered by phantom power, etc.) and if you’ve tried other configurations/microphones to solve the issue.
02-07-2014 04:22 PM
Hello,
I have the same problem with my canon 5d mark3 and my Rode MIc SVM. The Camera and Mic are new. The sound of the Rode Mic is terrible I can't use it. It also only seems to function when the manual soundlevels are put to the max.
Which plug in are you talking about. Here is a videofile wth soundsamples of 3 different mics so you can listen.
https://www.dropbox.com/sh/avskbgslad2bdsj/uRlXrf5vJO
Thank you
02-07-2014 04:27 PM
Hello, I have the same problem with my canon 5d mark3 and my Rode MIc SVM. The Camera and Mic are new. The sound of the Rode Mic is terrible I can't use it. It also only seems to function when the manual soundlevels are put to the max. Which plug in are you talking about. Here is a videofile wth soundsamples of 3 different mics so you can listen. https://www.dropbox.com/sh/avskbgslad2bdsj/uRlXrf5vJO
02-10-2014 05:37 PM
02-10-2014 05:41 PM
Appearantly you need to turn of the automatic gain control in the camera
but that is not so easy
http://www.youtube.com/watch?v=fnQAd23wFes
02-10-2014 06:01 PM - edited 02-12-2014 05:17 PM
Thanks. When I follow the instructions in the manual to do that, I don't get the icons, so I'm guessing the Vixia 400 doesn't have the option to change the gain.
Update: had to find several different sites to explain the various steps, but I was able to set the camera to P, then find the audio icons to turn off auto gain control. Still have the buzzing, even with ambient light.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
