12-04-2024 11:21 AM
12-06-2024 06:19 PM
Hi MatthewR,
I'm sorry to hear you are experiencing audio level issues with your camera. Looking at your trouble shooting you already tried everything we would recommend for an issue like this. Since this is happening with multiple microphones and XLR cables that would indicate there is an issue with the camera itself.
There is one thing you could do just to double check. Try using ACL Link to link CH1 and CH2 to see if the same thing happens. With both of those channels linked the camera should force both inputs to use the exact same settings, so both should show the same audio levels. If there's still a difference when they are linked we would recommend sending the camera in for repair.
If you need to send the camera in for repair, the Canon U.S.A., Inc. online repair portal allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
01-09-2025 03:27 PM
Thank you for the reply and information! Now that I am back in the thick of things after the holidays, I will definitely try ACL Link to link CH1 and CH2 to see if the same thing happens. If that does show the same issue, then yes, I'll begin the process of sending the camera in for service.
