EOS R5 C Audio getting clipped
synergy21
Hi community,
I am a Canon customer for many years, I had the EOS77D, then the 6D, and now the CANON R5C. I always used my RODE PROMIC, and with all my camera to have the best audio I lowered the level nearly at the minium, and put my Mic at +20DB.
With the CANON R5C, I started using it a LEVEL 10, which works well for a time, then I noticed my audio started to be clipped.
Now I figured out that when you put the audio level below 16, (15 to 0), besides lowering the volume of audio input, it lower the maximum limit, which means at a certain level (10) my audi are always clipped.
So you can see with a real test , on this next video (3secs) I recorded the same audio with Chanel 1 at level 16, and chanel 2 at level 10.
https://www.youtube.com/shorts/YNhum_Xh6Bshttps://studio.youtube.com/video/YNhum_Xh6Bs/edit
As you can see, the maximum level will be different., and the audio of chanel 2 is stuck and will be clipped.
The result will be like in this video
https://www.youtube.com/shorts/929chMVY6cU
So as you can see the issue is from the camera. I tried with many diferents mic, it always the same. The thing is to get the perfect audio, level 10 was the best, because I got 0 pitchy sound, and with the +20DB of the mic the voice was perfect. But now, I cant do that anymore, and I really dont know what happened, or if someone has the same issue.
I factory reset my camera 2 times, updated to the last firmware available, nothing.
Thank you!
And the s
1 REPLY 1
Since you now have 2 posts on this topic and have not found a solution, I would suggest reaching out to Canon Support.
My Canon - USA
Outside US
Canon Global
