08-20-2019 08:47 PM
08-21-2019 04:08 AM
As far as I know the only way is with wi-fi. However I have found that there is some lag between the camera and the display.
08-21-2019 08:30 AM
Hi jnptruck,
IamintheUK is correct, you can view the LCD information on your tablet using the WiFi on the camcorder and the Browser Remote function although there is likely to be a little bit of lag time between the camcorder seeing something and it being shown on the tablet. The WiFi setup guide for your camera can be found in the link below.
http://gdlp01.c-wss.com/gds/0/0300022030/02/hfg40-wifi-bsg2-8l.pdf
08-21-2019 12:47 PM
08-21-2019 03:31 PM
You can't unless the S6 has an HDMI input.. You are trying to do something it was never designed for.
08-22-2019 12:56 AM
That's correct, the camcorder can output live video via HDMI into an external monitor or recorder, but most tablets will not function strictly as a monitor or external recorder.
09-25-2019 04:54 PM
09-26-2019 12:48 AM
Hi TravisW,
Unfortunately the lag is going to be due to the connection and delay of the wireless communication. This can be improved with a stronger connection (items loser to each other) but I suspect the image will never be axactly as live as if you were to use a wired HDMI connection.
