XF605 Shutter Angle?
JCin
Enthusiast
Hello, I'm trying to get my XF605 to display Shutter Angle as I have it set with my R5C and C70. On the C70 for example, there is Shutter Mode in the menu which you can set to angle and the the screen displays the shutter angle, 180. On the XF605 I do not see this in the menu, although there is the external shutter switch on the side of the camera. How can I have the display show Shutter Angle and not Speed on the XF605?
See pages 62.
xf605-im10-en.pdf
https://share.google/PfqNGkTRuhIjvba9V
Changing the Shutter Speed Mode
Set the SHUTTER switch to ON and then slide the
switch toward SEL to change the shutter speed mode.
• Repeatedly pushing the switch toward SEL will change the
shutter speed mode in the following order: Speed
Angle  Clear scan  Slow  Automatic.
2 REPLIES 2
See pages 62.
xf605-im10-en.pdf
Thanks shadowsport! I was trying that earlier this week and seemed that it wanted to change the shutter speed. I will give it another go when I get in tonight.
