01-16-2015 03:58 AM
Hi Canon Forum.
I know this is a replay to a non related thread, but since it was not possible to make a new thread, I have to do it this way.
I have a serious connection problem with my MVX4i Canon Camcorder.
First my hardware:
O/S: Win7 64bit
What happens:
I've installed the drivers but I keep getting the error "cannot detect camera".
In my device manager it claims that the drivers cannot be installed and even though I manually search for them (on the installation CD or the installation directory) it refuses to install them.
What I have tried:
I've tried using different USB ports - no luck
Used different USB cables - no luck
Tried uninstalling EVERYTHING, disconnecting camcorder and installed drivers again - no luck
I've tried drivers from your website instead of the CD - no luck.
What in gods name can I do to get my PC to connect with my camcorder??
01-21-2015 11:18 PM
Just out of curiosity, what drivers from the web site are you using? Is the camera set to the Play (VCR) mode when you connect the camcorder?
Skipping step 1 which is to turn on your computer, you may need to try the following if you have not already done so:
2. Set the camcorder to Play (VCR) mode.
3. When using a USB cable:
Press the MENU button and select [VCR SETUP]. Select [AV -> DV/(USB Symbol)], set it to [OFF] and press the MENU button.
4. Connect the camcorder to the computer using the USB cable.
Forgive me if these are things you have already tried.
01-22-2015 05:38 AM
Hi Videogeek.
I'm sorry in advance if the following sounds rude.
The instructions you suggested are the absolute basics of the user manual and among of the first things I've tested.
Even though I don't understand why the setting "AV-USB" should be turned off, I did it anyways.
I've tested the camcorder on a computer with WIn XP and it works fine there.
01-22-2015 10:33 AM
Your reply was not rude at all. Hopefully someone from Canon or another owner of that camcorder model will be able to help. I don't own a Canon that uses tapes and the camcorders that I do have that use tape connect via a Firewire connection. If I come across anything that will be useful then I will post a reply.
01-22-2015 11:17 AM
That is very nice of you.
The reason i want to connect the camcorder, is soley to transfer my old MiniDV tapes to my computer.
01-22-2015 12:54 PM
I'm not sure this will help but you could try uninstalling the USB Controller drivers and after a shut down or restart the drivers will reinstall.
From the Microsoft site:
Method 3-
I would have you re-install the USB controllers.
Refer the steps-
a) Click Start, then type device manager in the Search box, and then click Device Manager.
b) Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
c) Once complete, restart your computer. The USB controllers will automatically install.
If it is a device driver that is needed then hopefully someone from Canon will respond and point you in the right direction.
I don't know if anything from this Canon page will help or not but it may be worth looking at if you haven't done so already.
