01-31-2017 05:17 PM
Hi!
Relatively new to Canon camcorders, I've noticed that low-light videos recorded with the newer R600 tend to be much grainier than what I record with an M40. Adjusting the R600's settings only seems to make things worse or lowers the framerate.
Which direction should I look in for an upgrade from the M series?
Thanks!
-Michael
01-31-2017 06:51 PM
Hi Autolooper,
Thank you for posting.
The sensor in your VIXIA HF M40 has better low-light performance 0.1 lx (low light mode) than the VIXIA HF R600 0.4 lx (low light mode).
01-31-2017 06:51 PM
Hi Autolooper,
01-31-2017 08:30 PM
Thanks for the info!
Would you have any suggestions for an upgrade over the M series?
06-29-2022 11:26 PM
The M40 also has a bigger sensor size than the R600, the former has a 1/3 inch sensor found on prosumer cams while the R600, a lower end cam, has a sensor slightly bigger than 1/5 (1/4.85) which isn't really enough for a clean low light image. The bigger the sensor, the more light it receives
