06-13-2021 11:47 PM
Hey folks,
I'm trying to use my HF G50 camcorder as a live video source in visual performances with an old video mixer, specifically a VIDEONICS MX-1. Unfortunately the signal coming from the mini HDMI output seems like its only compatible with a standard HDMI monitor. I get no signal when using the HDMI to RCA cable that works just fine with my computer. I get no signal when going straight into the projector.
Has anyone had any luck getting a signal on anything other than a hdmi monitor? Is there a converter or a processor that can expand on whats "compatible" with this camcorder?
I appreciate any assistance!
tim
07-09-2021
03:45 PM
12:50 PM
Tim,
I have not tried this nor do I have a HF G50 camera. I would recomend trying an adapter with a power supply. Check this link at Amazon for a possible solution. I have found some signals need power / amplification to work on other devices.
[Commercial link removed and replaced with screenshot to facilitate discussion.]
09-13-2021 01:10 PM
Tim,
Anytime you have an HDMI signal you have to convert it to a format suitable for your computer or other device. I have used an Elgato Cam Live (available on Amazon). I also am using a Blackmagic ATEM Mini switcher for live streaming to Facebook, Zoom, etc. for live church services. That unit has a built-in converter, so none needed. This will be the case for any video camera with an HDMI feed.
