08-11-2024 10:38 PM
I downloaded and installed the new firmware version 1.0.1.0. I can see the "custom picture" option on page four of the camera setup menu, but it is greyed out. I am unable to select it and enable custom picture. Why is this? Is there any fix? Thanks!
08-13-2024 09:07 AM
Hi unigrampa,
The custom picture option won't work in certain settings. Make sure the power switch is set to the CAMERA, not MEDIA, position. Then try putting the camera in the M mode by using the switch on the top of the camera.
08-13-2024 09:07 AM
Hi unigrampa,
08-13-2024 09:12 PM
It was in camera mode. Switch to manual!! That's probably it! I will return to accept your solution if that works!!
