Can't initialize new memory card; Vixia HF S100
CamraMaan
I just bought two new memory cards, and neither one will initialize correctly on my camcorder... it goes through the process on the screen, but afterward, it seems like nothing has changed, and it says the cards still need to be initialized.  One is an Onn 256gb (U3), the other is a SanDisk 64gb (U1).  Not sure what information to provide, but hopefully someone can help...  🙂
Thanks in advance!
The maximum card size for that camcorder is 32GB. and they use the FAT file system. You must format the cards in the camcorder and not your computer as this can cause recording problems.
__________________________________________________________________________________________
EOS C100 mk2 with a Canon EF-S 18-135mm IS STM, and a Sigma EF mount 10mm-20mm EX DC HSM wide angle - Zoom H2Essential - Dell 8700 i7-4790 3.6Ghz, 24GB Ram, Win 10, Nvidia GTX 1060 6GB - DaVinci Resolve Studio 20.3 - Blackmagic Speed Editor - Presonus Faderport 1.
5 REPLIES 5
Here are the requirements for your camera:
CamraMaan
I appreciate the info, but I saw the same in my manual before I purchased the cards.  They're both class 10, so I figured that shouldn't be the issue...?
I'm also curious what file system to format the memory cards in, if using my computer?  It defaults to exFAT, so I just want to make sure that's not the problem?
Again, thanks for any/all help!  🙂
I should add that the camera recognizes and uses similar, but older, memory cards just fine, but none are larger than 32 GB.
Thank you!  I had a feeling 32 GB was a max.  Sad day...  😞
