Reconnecting MP620 to Wifi
plabaste
I upgraded the router and the printer does not seem to recognize the new WiFi network. How can I reconfigure it?
PatrickL
11 REPLIES 11
From your printers support page:
Windows
ArthurJ
Hi plabaste,
Just wanted to check in and see if your were able to get the printer reconnected. If you were able to, please click the Accept as Solution button in shawdowsports reply post so that others may find the answer as well.
We look forward to hearing back from you.
Nope
PatrickL
Hi plabaste,
What version of Windows or Macintosh is installed on your computer? Also do you still have the usb cord that came with the printer?
Windows 10.
Unfortunately not.
PatrickL
Hi plabaste,
If your router has a WPS button ( would say wps, has an icon of curved arrows or an icon of a lock) then please click HERE for steps to connect the printer via the WPS method.
If your router does not have a WPS button, you would need to get a printer usb cord(A to B usb) cord and use that to during the install to connect the printer to your network.
Hi ArthurJ,
Thank you for your advice.
The router does have a WPS button.I followed the step-by-step procedure as indicated and aftre a couple of unsuccessful attemps I saw the message procedure completed successfully on the printer. The bad bnews is that when I try to print I still get the Error message: Printer not responding.
PatrickL
Hi plabaste,
I would get the network setting on the printer. Please click HERE for steps on checking the Wireless LAN setting list.
Once you are able to see the settings, please let me know what the connection and signal strength is. I would also make sure the SSID matches the network your computer is connected to.
Hi ArthurJ - I checked the Wireless LAN Setting List as recommended. It shows that the connection is Active and displays as SSID the computer's network name. However it still impossible to print. It doesn't show any information on signal strength.
PatrickL
Friends and Family
