PIXMA TS6300 Series: Can't connect via Wi-Fi
David103
I cannot connect to my printer via wifi. I have tried everything, resetting the printer wifi, reconnecting the wifi. I am connected to the same wifi as the printer. I have tried switching off and on again. Nothing works. I can connect to the printer via direct wifi, but this is not ideal
1 REPLY 1
Moderator
Moderator
Thanks for joining the conversation, David103!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TS6300 series.  Its model number should appear on the front of the unit at the bottom right corner. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
