03-10-2021 02:27 PM
I have an ST-E3-RT with two Speedlite 430 EX III-RT's.
This works great from behind the camera to control the power output of each speedlite. However, there are ocasions when I need to change the flash power on the speedlite's when being away from the camera.
Can I select the power individually on each of the speedlite's without using the ST-E3-RT?
03-13-2021 06:50 PM
03-10-2021 02:55 PM
I don't think so.
What I have done in the past (more for just a workaround of going beyond the five group limitation) is to add ND gels to flashes as needed.
But outside of zoom (which cannot be done via the ST-E3-RT), I control all other settings with it from the camera.
03-11-2021 01:58 PM
I find it difficult to belive that having invested $1200 in a Canon lighitng kit, that it can't do a simple manual setting off camera.
I know other photographers using other brand speedlites and various triggers can do it, so there must be a way?
03-13-2021 06:50 PM
11-03-2021 08:48 AM
I have just purchased a Canon R6 and a Speedlite 430EX III-RT, and also own a 430EXII and a Speedlite Transmitter ST-E2.
Is there a way of getting both flashes to work with the R6, either using the master/slave function, or firing both from the ST-E2?
I can get to ST-E2 to fire the 430 EXII but not the 430 EXIII-RT
11-03-2021 09:08 AM
Is the 430EX III - RT set for optical wireless flash?
11-03-2021 09:35 AM
Yes, I have checked this, thanks
