02-05-2021 07:01 PM
Hi Guys,
My canon speedlite 430 EXiii-RT was working well until i had to change the battery. I replace the battery, the test is firing but the flash is not firing anymore when I take a picture. Is there a simple way to fix this?
02-06-2021 09:11 AM
How are you triggering the flash? What mode was the flash in before you changed the batteries?
When you change batteries, the flash units will often reset some settings. Unless you replace them witin 1 minute (see page 19 of the User Manual).
02-08-2021 05:22 PM
Hi, thanks for your answer. It actually works the day after for a reason I ignore. It is working right now
