02-07-2024
10:48 AM
11:05 AM
Good afternoon.
I'm interested in purchasing a Canon R50, but I'm having trouble finding a Flash that will fit.
Is there a flash that does not require the adapter? Godox or Yongnuo?
Thanks.
02-07-2024 12:12 PM
You could use the Speedlite EL-5 which doesn't require the Multi-Function Shoe Adapter AD-E1.
07-20-2024 05:49 PM
I read somewhere that the 580ex2 works with the r50 without the unavailable adapter, but that makes no sense since the hotshoe is completely different.
07-20-2024 08:08 PM
No it won't work because the camera lacks the pins for older EX and 5 pin EL series speedlites to work. Cameras such as the EOS R7 and EOS R6 Mark II have the legacy 5 pins and the new digital connection pins at the front of the hot shoe. This preserving backward compatability with older EX and 5 pin EL series speedlites.
07-21-2024 04:06 AM
When the hotshoe looks like this the only devices compatible are ones with the 21-pin multifunction shoe fitting.
Such unit currently are…
