10-16-2014 10:16 AM
10-16-2014 10:51 AM
Make sure the flash says ETTL in the upper left corner. Use the mode button to flip through the different modes:
http://learn.usa.canon.com/app/pdfs/quickguides/CDLC_Speedlite430EXII_QuickGuide.pdf
Also, you should be aware of how your camera shooting mode meters based on having a flash present. Here's an article:
http://www.scantips.com/lights/flashbasics4.html
It's just the first decent one I found, I didn't look into it too much, but it covers the different shooting modes and how they react to flash. it's written for Nikon, but should translate the basics fine (just note that A = Av, S = Tv, etc). I highly recommend a solid understanding of the different shooting modes to understand flash photography.
10-16-2014 12:58 PM
10-16-2014 01:53 PM
Yes I have the same flash. On my 7D or 6D (also the EOS family) I just need to put the flash in ETTL mode, like the others have said.
10-16-2014 04:02 PM
@Skirball wrote:Make sure the flash says ETTL in the upper left corner. Use the mode button to flip through the different modes:
Gisle Hannemyr wrote (in English) a good article a few years ago on the eccentricities of Canon's ETTL and how to use it properly. A quick Google search didn't turn the article up, and I don't have time just now for a more exhaustive search, but it should be out there somewhere.
10-16-2014 04:16 PM
Sure, and if you really get into flash then it's probably worth looking into the eccentricities - although you'll probably discover them sooner or later just through use anyway.
But I just meant to reinforce that the camera/flash behaves very different in green box or P mode than it does in Av or Tv mode. And that it's worth understand how, and in what conditions. Mostly, it's worth knowing that Canon flashes will always default to fill flash when in Av, Tv, or even Manual with eTTL. I believe that Nikon systems don't work the same way. It's worth understanding these basics or you're going to run into trouble - as people usually do when using Av in a really dark situation.
10-18-2014 11:05 PM
10-18-2014 11:51 PM
10-19-2014 08:04 AM
@jrhoffman75 wrote:
Is this [the Gisle Hannemyr article that Bob referred to earlier]?
http://dpanswers.com/content/canon_flash.php
Probably. I'm not sure it was organized just that way before, but the content seems to be at least as detailed. It's probably a little more up-to-date, but still not recent enough to mention the 600EX-RT. If anybody runs across a later version, please let us know.
10-19-2014 11:40 AM
