08-18-2024
12:26 PM
10:49 AM
Will my current R5 flash triggers work with my new R5 Mark II? I've seen conflicting answers to this?
I have the Canon AD-E1 Multi-Function Shoe Adapter on order, but I would like to be able to shoot with my off-camera flashes without the adapter if possible.
08-19-2024 08:12 AM
Is the trigger Canon or 3rd Party. If 3rd Party there maybe incompatibilities. If Canon only weather sealed speedlites need the adapter.
08-24-2024 11:22 AM
I use both Godox and Flashpoint triggers. I'm currently using the new Godox X3-C trigger and love its tiny footprint. I have a Canon EL-1 flash but I don't like to put it on the hot shoe as it's so heavy and mount it to a ProMediaGear Boomerang L-bracket when I'm not doing off-camera shooting. Now that I've got my R5 Mk II, I hope to get a chance to test it this weekend.
I don't really care about weather sealing as I'd never take my camera out in the rain.
09-04-2024 07:24 PM
Hello,
I cannot enable my Wescott FJ-X3m trigger and FJ200 flash into High Speed Sync. I can get it to fire, but not above 1/200th. The Flash Function Settings are grayed out with "TTL and 1st Curtain" buttons on the screen. Westcott is perplexed as well.
Patrick
09-04-2024 07:28 PM
Your 3rd Party flash system is incompatible with the camera. This is on them to fix not Canon.
09-04-2024 07:30 PM
Copy.
Been in contact with Wescott and they are telling me it's the camera settings...
thanks.
patrick
09-04-2024 07:34 PM
Does a Canon Speedlite work correctly. This happens all the time with 3rd Party gear. It works fine on older cameras. But it won't work correctly on newer bodies.
09-04-2024 07:42 PM
i just have Westcott flashes. My westcott speed light is the same.
09-04-2024 07:46 PM
It's a compatibility issue between old 3rd Party gear and a new camera body. This happens all the time with 3rd Party gear.
09-05-2024 08:38 PM
I use both Godox and Flashpoint triggers on my R5 with the EL-1 flash as well as Godox and Flashpoint flashes. I have never had a problem with the triggers on my R5 Mk 1.
