Canon Speedlite 420EX or 430EX Compatibility with EOS Rebel T7
Tony106
Are subject flashes compatible with the Canon EOS Rebel T7?
2 REPLIES 2
deebatman316
All EX and EL speedlites are compatible with your camera. Note speedlites released prior to the 430EX II and 580EX II (before 2008). Are NOT compatible with the speedlite control menu which has been a feature in all EOS cameras since 2007. Also note older speedlites such as the 420EX don't factor in sensor size. Newer speedlites factor this in which prevents over and underexposure.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
MikeSowsun
Any flash that ends in “EX” will be compatible. 380EX, 420EX, 430EX, 430EX II, 430EX III, 580EX, 580EX II, etc.
Newer flash units like the 430EX II, 430EX III, and 580EX II will also be compatible with your camera’s in-camera flash menu. Older flash units will need to have any setting changes made right on the flash itself.
Mike Sowsun
