Canon 600EX II-RT drops link- HELP!
Phillyphoto
Scenarios I have tried:
Using Canon Transmitter ST-E3-RT as the master and (2) 600 EX II-RTs as slaves.
Using A 600EX as master and B 600EX as slave.
Using B 600EX as master and A 600EX as slave.
I get the same result of the slave dropping link. The time varies. Sometimes it drops link in 4 mins, sometimes 10mins, sometimes 20 or more minutes. The only way to relink them is by turning everything off and back on.
All channels are the same. Yes, I have scanned for the best connection as well as every other channel and AUTO.
All IDs are the same.
Not near a wifi-router or airport, I'm in a row home in Philadelphia.
Using NiMh rechargeables and using freshly charged batteries for every test. Batteries are about 2 years old.
I have spoken to 2 Canon service reps and neither of them has any idea what the problem is. I really don't have the money to spend on sending everything in for "repair".
Any help is greatly appreciated, thanks!
202 REPLIES 202
Because Godox implemented the interface properly!
I use Phottix Laso adapters which are 100% compatible with the Canon RF system and they also work great. They also make (made) a fully compatible controller which also works perfectly, so far...
Canon have simply messed up somewhere. This has most likely only become a problem as modern WiFi systems (including my Apple home pods) introduced what I believe to be new broadcast messages. While these perfectly legal network messages happily pass through my entire WiFi, Ethernet and Powerline networks, they trip up the Canon flash system at the other end.
If you turn off the transmitter (the controller and flashes are actually all transceivers) and wait until the flashes have tripped up, you've effectively just performed a fresh restart of the transmitter. It will most likely work as expected, for a while, unless you're unlucky with the timing. Try leaving the entire system running until the flashes turn red. The controller will still look ok, the led remains green and the status indicators show that all flashes are still connected (although they're not). If I do this, and power cycle just the flashes, in my environment, the flashes will not reconnect unless I also power cycle the controller.
The Phottix Laso adapters and controller do not have this issue. They are fully compatible with the Canon system which indicates that although the issue may be due to some periodic 2.4GHz signals, which I wouldn't necessarily call interference, it does show that the underlying system/protocol is actually fine. Canon have just messed up with the failure recovery / robustness.
If I were to start over I'd buy Godox - but for yet another reason - apart from saving money. Canon only make small "on camera" type flashes. You're out of luck if you want anything more powerful later. I've just added 2 Godox AD400's with a X2T-C controller, that's the older one with the hotshoe. I can then mount a Canon/Phottix controller on the X2T-C hotshoe to get 5 groups on the Godox system plus another 3 groups on the Canon/Phottix (I don't know why all 5 are not available). It's not exactly convenient but it does work.
Note: I only use manual flash mode and I suspect only group A on the Canon controller will work in TTL mode, but I've never tested it.
I have 4 600 RT's with the single EL-1 on my camera controlling them. Some situations it works fine all night.  Except some venues it drops the connection every 5 minutes or so, I have to manually turn off and on each flash to make them turn green again. Doesn't matter if I scan for channels, I've literally tried all 15 channels in a single night, same issues over and over and over.  SOMETIMES I have to power cycle the on-camera flash, but that's random.  SUPER frustrating for professional gear.  It's always in venues that have venue wide wifi.
garmanmd
I have also struggled with this problem of losing sync seemingly when newer wifi is present.  I have heard that Phottix Laso can drive canon RT flashes.  Does anyone know if it has been tested and that this solution works in the same settings where the Canon triggers fail?
I would like to know also. Thank you!
I talked to B&H and while they still have some Photix triggers in stock, they aren't making them anymore and they are just running stock out, so buy with caution.
First of all, as mentioned by Garmanmd, the Phottix Laso system is no longer produced. I managed to pick up some additional triggers and controller at a significantly reduced price from theflashcentre.com in the uk, but now I can only find the controllers in their webshop.
In my environment all 3 of my 600EX-RT(s) and the ST-E3-RT lock up within at least 8 minutes, guaranteed! The Phottix Laso triggers and their controller DO NOT. I also bought a YONGNUO YN600EX-RT II for comparison purposes and it also runs with zero lockup issues.
I listed my tests (prior to purchasing a Phottix controller) in this post.
I now have 7 Laso triggers and 2 controllers and use them on 3x 600EX-RT and 4x 550EX flashes with absolutely no issues to date.
HOWEVER, as I mentioned in an earlier post, I would personally now recommend using Godox X1R-c triggers on 600EX-RT flashes (unfortunately they do NOT appear to work on my older 550EX units) and either the XPRO II or X2T-C controllers instead. They're not compatible with the Canon RT radio system (which I don't think is a great loss) but the triggers are smaller and less expensive than the Phottix Laso triggers. The Godox range of flashes also extends to studio type heads if you ever need anything more powerful. I recently purchased 2x AD400pro flash heads, so instead of firing 4 strobes into an umbrella, I now fire an AD400 into a large soft box - there's simply no comparison! Canon offers nothing like this at all. So far, the only issue I've had was changing the channel inadvertently when removing the X1R from the flash without turning them off. The channel button is easily pressed, but now I'm aware of it. Otherwise everything has worked perfectly, no hiccups whatsoever. I only wish I'd gone this way earlier, it would have saved a lot of cash and frustration...
AdamFalgout
I bought Yuonguo (something like that) and those don't ever seem to drop connection.
when you say the Godox X1R-c are not compatable with Canon RT system, does that mean you are using them in the older optical mode denoted by the lightning bolt?  I have an old school canon ET-S2 transmitter that will also do that, although more limited in its choices and of course brings back all the limitations RT fixed (or at least fixed until recently when they stopped working correctly).  It is a bit astounding that Phottix could figure out to solve this problem in the trigger only, and Canon either cannot or does not want to.  They remain completely silent on this problem, and give no solutions.  I've been a Canon shooter for over 50 years, and find this very disappointing.
I decided to call Canon support one more time.  The tech of course was very familiar with the problem, and the official answer he has been given is that Canon is aware of the problem and is working on it but does not have a solution yet.  Of course this problem goes back several years, so it is astounding Canon can't figure it out after all this time.  Other mfg in their systems don't seem to have the problem so it doesn't seem like it's such a big mystery.  So overall not a particularly helpful answer, and we are all in the same place we have been
