08-24-2014 05:27 AM
I cannot get my 600ex-rt's to fire optically with my profoto strobes. Does the 600 not have a traditional optical trigger and if so, what is the setting for it?
08-24-2014 06:40 AM
This may be what you want.
08-24-2014 07:02 AM - edited 08-24-2014 07:05 AM
Thanks, to be clear though, even to fire optically...its really infrared from the ST-E2 transmitter, the 600ex wont trigger from optical light from a strobe.....correct? I am using the new Profoto B1 with the TTL-C controller where the ST-E2 would mount on the hot shoe, so besides using a cable to the ST-E2, I want my 600's to fire from the firing of my B1's.....make sense?
08-24-2014 07:08 AM
I think thats the case.
08-24-2014 07:12 AM
08-25-2014 12:13 PM
@Corvette95 wrote:Thanks, to be clear though, even to fire optically...its really infrared from the ST-E2 transmitter, the 600ex wont trigger from optical light from a strobe.....correct? I am using the new Profoto B1 with the TTL-C controller where the ST-E2 would mount on the hot shoe, so besides using a cable to the ST-E2, I want my 600's to fire from the firing of my B1's.....make sense?
Can't be done, without additional equipment. Canon refuses to put simple optical triggers in their flashes; there's only the Canon Optical System, but your B1's don't speak that language. Are you trying to shoot in eTTL? I doubt it's possible to use two different eTTL systems simultaneously. The instructions posted above are for stroboscopic effects, that has nothing to do with what you're trying to do.
You could get an optical peanut, but that would only work in manual of course. And it'd be amusing to use a peanut to trigger a 600ex-RT.
http://flashzebra.com/products/0118/index.shtml
08-26-2014 09:57 PM
I have tried optical adapters - the cheap ones from Ebay, to fire the 600, it will fire it one time, then will not fire again. I either need an optical trigger or a dual sync cable set up (two 600 ex-rt's) and fire them in manual mode. Any help on what I can do. If you have specific product recommendations that would be great! What size sync cable will work with my 5D Mark III and my 600ex-rt?
