470ex AI auto metering to avoid overexposure
johnrmoyer
Whiz
Whiz
I know little about speedlights. I seem to get things over exposed often. It seems that I do not understand how auto metering works when the speedlight is attached.
I was experimenting with using a flash with wildlife in deep shade. I was using Speedlite 470EX-AI on the camera and set for straight ahead with no bounce or automatic movement.
I used -2/3 exposure compensation for the squirrel, but it still seemed over exposed. I used "flash priority" metering because I was not wanting to lighten background shadows.
The Squirrel image was processed in DPP, saved to 16 bit TIFF, loaded into gimp, additional noise reduction and unsharp mask in gimp, saved from gimp as JPEG with quality 85 and 4:4:4 sampling. The low quality setting was to get it under 5 MB for upload here.
The eye of the squirrel has reflected the flash, but I did not try to fix that.
ExifTool ExifToolVersion 13.30
File:Other FileName IMG_4319.dr4
CanonVRD:Image AngleAdj 0.7
CanonVRD:Image WorkColorSpace sRGB
CanonVRD:Image RawBrightnessAdj -1
CanonVRD:Image WhiteBalanceAdj Shot Settings
CanonVRD:Image ColorSaturationAdj 1
CanonVRD:Image UnsharpMaskStrength 2
CanonVRD:Image UnsharpMaskFineness 4
CanonVRD:Image UnsharpMaskThreshold 5
CanonVRD:Image HighlightAdj -1
CanonVRD:Image DLOSetting 50
CanonVRD:Image DLOOn Yes
CanonVRD:Image DPRAWMicroadjustBackFront 0
CanonVRD:Image DPRAWMicroadjustStrength 8
CanonVRD:Image CropRotatedOriginalWidth 8258
CanonVRD:Image CropRotatedOriginalHeight 5564
CanonVRD:Image CropX 713
CanonVRD:Image CropY 1341
CanonVRD:Image CropWidth 6000
CanonVRD:Image CropHeight 4000
CanonVRD:Image CropRotation 0
CanonVRD:Image CropAngle 0.7
CanonVRD:Image CropOriginalWidth 8192
CanonVRD:Image CropOriginalHeight 5464
ExifTool Warning Bad length ICC_Profile (length 3140)
File:Other FileName IMG_4319c.JPG
File:Image ImageWidth 6000
File:Image ImageHeight 4000
EXIF:Camera Model Canon EOS R5
EXIF:Camera ExposureProgram Aperture-priority AE
EXIF:Camera Flash On, Fired
EXIF:Camera ExposureMode Auto
EXIF:Camera SceneCaptureType Standard
EXIF:Image Software Digital Photo Professional
EXIF:Image ExposureTime 1/250
EXIF:Image FNumber 11.0
EXIF:Image ISO 2500
EXIF:Image LensModel EF100-400mm f/4.5-5.6L IS II USM +2x III
MakerNotes:Camera CanonFlashMode External flash
MakerNotes:Camera ContinuousDrive Continuous, Low
MakerNotes:Camera FocusMode AI Servo AF
MakerNotes:Camera RecordMode CR3+JPEG
MakerNotes:Camera CameraISO Auto
MakerNotes:Camera FlashActivity 157
MakerNotes:Camera FlashBits E-TTL, External
MakerNotes:Camera CameraTemperature 39 C
MakerNotes:Camera CanonFirmwareVersion Firmware Version 2.2.0
MakerNotes:Camera ShutterCount 24400
MakerNotes:Camera CanonModelID EOS R5
MakerNotes:Camera ValidAFPoints 1
MakerNotes:Camera MeasuredRGGB 630 1024 1024 495
MakerNotes:Camera WB_RGGBLevelsAsShot 1975 1024 1024 1879
MakerNotes:Camera ColorTempAsShot 5228
MakerNotes:Camera RollAngle 0.7
MakerNotes:Camera PitchAngle 2.9
MakerNotes:Camera FocalLength 800 mm
MakerNotes:Image MeasuredEV 9.75
MakerNotes:Image ExposureCompensation -2/3
MakerNotes:Image MeasuredEV2 13
MakerNotes:Image FocusDistanceUpper 18.82 m
MakerNotes:Image FocusDistanceLower 15.17 m
MakerNotes:Image ShutterMode Electronic First Curtain
Fox Squirrel (Sciurus niger) on Parthenocissus quinquefolia vine in Norman, Oklahoma, United States on August 2, 2025Fox Squirrel (Sciurus niger) on Parthenocissus quinquefolia vine in Norman, Oklahoma, United States on August 2, 2025
p4pictures
Hi John,
To my eye, this shot does not look overexposed, certainly the flash element in the scene. With aperture priority added flash the camera by default will set the shutter speed from 1/60 to the sync speed 1/250 in your EOS R5 with electronic first curtain shutter. The fact that you have 1/250 suggests you have set the Slow synchro setting for a fixed shutter speed as I would expect 1/60 to be selected with default settings here. Though equally that could be a result of the ISO 2500 selected as the camera tried to balance the ambient light.
Selecting flash priority flash balance would conventionally mean that the photos look a little more "flashed" than Canon cameras normally aim for. I tried the flash balance settings in the past, but actually prefer the standard flash balance setting.
https://www.p4pictures.com/2022/05/e-ttl-balance-speedlite-settings/
With your ISO so high it is possible that f/11 from your lens + extender, and 1/250 are the maximum settings the camera can work with, and despite you selecting -2/3 EV on the ambient compensation, the image was already overexposed with ambient light and 1/250, f/11, ISO 2500. Adding flash simply adds more light.
One suggestion is to try using manual mode on the camera, setting the shutter speed to the sync speed of 1/250 you chosen aperture and then adjust ISO to give you the ambient exposure you want, even if that is underexposed. Then when the flash is used it will illuminate the detected subject, but the flash intensity will fall off the further the light travels, meaning the background will be darker.
As an example here is a photo taken with flash inside a butterfly enclosure. I set the camera to manual mode and chose 1/200 f/4 ISO 200. The flash was set for E-TTL automatic flash exposure. Without the flash the frame would be very underexposed. So the camera determines the flash exposure and illuminates the subject but the light falls off the further from the subject it goes.
Brian
3 REPLIES 3
deebatman316
What do you mean by Auto Flash metering. Do you mean E-TTL. I believe the camera uses more flash power when set to flash priority. If you don’t want fill flash you should avoid using full automatic or semi automatic modes. Also avoid Auto ISO and Manual mode on the camera. This puts the camera into fill flash mode also. In Full Manual mode on the camera and the flash set to E-TTL. This will treat the flash as main light and the only light source. For more information check with @Brian I’m not near my 470EX-AI for testing. Nor do I own an EOS R5 to test it out on.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 85mm F/1.8 USM
p4pictures
Hi John,
Brian
Thanks to Brian for explaining in a manner that made sense to me.
I used Fv mode and specified shutter speed, FNumber, and ISO. The camera obtained proper metering by controlling the flash.
This year, painted buntings have not been willing to pose for me in a tree, but still come to a bird feeder when there is not much light.
File:Other FileName IMG_4339cs.dr4
CanonVRD:Image DR4CameraModel EOS R5
CanonVRD:Image Rotation 0
CanonVRD:Image AngleAdj 0.5
CanonVRD:Image RawBrightnessAdj 0
CanonVRD:Image PictureStyle Shot Settings
CanonVRD:Image ContrastAdj 0
CanonVRD:Image ColorToneAdj 0
CanonVRD:Image ColorSaturationAdj 0.3
CanonVRD:Image ShadowAdj 0
CanonVRD:Image HighlightAdj 0
CanonVRD:Image DLOSetting 70
CanonVRD:Image DPRAWMicroadjustBackFront 1
CanonVRD:Image DPRAWMicroadjustStrength 7
CanonVRD:Image CropRotatedOriginalWidth 8239
CanonVRD:Image CropRotatedOriginalHeight 5535
CanonVRD:Image CropX 2010
CanonVRD:Image CropY 950
CanonVRD:Image CropWidth 4500
CanonVRD:Image CropHeight 3000
CanonVRD:Image CropAngle 0.5
File:Other FileName IMG_4339cs.JPG
EXIF:Camera Make Canon
EXIF:Camera ExposureProgram Not Defined ( exiftool does not know about Fv mode )
EXIF:Image FNumber 13.0
EXIF:Image ISO 400
EXIF:Time DateTimeOriginal 2025:08:05 07:10:13
EXIF:Time OffsetTimeOriginal -05:00
EXIF:Time SubSecTimeOriginal 96
MakerNotes:Camera MeteringMode Evaluative
MakerNotes:Camera CanonExposureMode Flexible-priority AE
MakerNotes:Camera CameraTemperature 41 C
MakerNotes:Camera ShutterCount 24420
MakerNotes:Camera MeasuredRGGB 947 1024 1024 463
MakerNotes:Camera WB_RGGBLevelsAsShot 2194 1024 1024 1651
MakerNotes:Camera ColorTempAsShot 6578
MakerNotes:Camera WB_RGGBLevelsFlash 2245 1024 1024 1628
MakerNotes:Camera ColorTempFlash 6806
MakerNotes:Camera PerChannelBlackLevel 2048 2048 2048 2047
MakerNotes:Camera AFConfigTool Case 1
MakerNotes:Camera AFTrackingSensitivity 0
MakerNotes:Camera AFAccelDecelTracking 0
MakerNotes:Camera AFPointSwitching -1
MakerNotes:Camera AIServoFirstImage Equal Priority
MakerNotes:Camera AIServoSecondImage Equal Priority
MakerNotes:Camera AFAssistBeam Enable
MakerNotes:Camera AutoAFPointSelEOSiTRAF Enable
MakerNotes:Camera InitialAFPointInServo Manual AF Point
MakerNotes:Camera SubjectToDetect Animals
MakerNotes:Camera EyeDetection On
MakerNotes:Camera RollAngle 0.5
MakerNotes:Camera PitchAngle 4.1
MakerNotes:Image MeasuredEV 8.12
MakerNotes:Image MeasuredEV2 3.5
MakerNotes:Image FocusDistanceUpper 9.07 m
MakerNotes:Image FocusDistanceLower 7.89 m
MakerNotes:Image FlashExposureLock Off
MakerNotes:Image AntiFlicker Off
IPTC:Other Keywords bird, bunting, Painted Bunting, Passerina ciris, birdfeeder, wildlife, wildlife photography, Oklahoma
XMP:Image Description Painted Bunting (Passerina ciris) in Norman, Oklahoma, United States on August 5, 2025
Painted Bunting (Passerina ciris) in Norman, Oklahoma, United States on August 5, 2025Painted Bunting (Passerina ciris) in Norman, Oklahoma, United States on August 5, 2025
