05-10-2020 08:34 AM
Hello there!
I have followed every instruction found at support section and tried different solution but no avail. My EOS Utility, 2 and or even 3 can not detect my Canon EOS700D. I can see my EOS700D on my computer connected but it seems I can not find solution for my problem. Here are some details;
Using:
Dell Inspiron 15 5000 series 64bit (Windows 10).
05-11-2020 01:57 PM - edited 05-11-2020 02:34 PM
One other thing to try that I saw on line.
Go to Device Manager->Portable Devices and delete the camera.
Then connect camera and turn it on to force the computer to re-find the device.
05-10-2020 10:00 AM
Welcome to the forum seanebue.
Issues like yours can be very difficult to resolve remotely because it could be caused my many factors.
I have a T5i (North American version of the 700D). It is detected fine on my W10 PC.
Did it ever work or is this a new camera or computer to you?
The fact that you can see the camera in Explorer would tend to rule out a USB port problem or a cable problem. But, if you are not using the cable that came with the camera I would suggest you try that.
I am not aware of any camera setings that would affect connection, but you could try resetting all camera settings in the Menu.
On the off chance that the program is corrupt you could download and install the latest versiion from the Canon support site.
Can you borrow a different camera from a friend to try. What about trying a different computer.
05-10-2020 10:12 AM
I assume that you connect the USB cable before turning on the camera. Sometimes, it seems like the EOS Utility needs to initially download a driver from the internet, so make sure that you have an active internet connection.
On some machines, the EOS Utility simply needs a jump start. You would need to go into the C: drive Programs folder, find where the Canon folder is located, and start the EOS Utility program manually. Once this has been done, it should automatically detect your camera when it is powered up, and launch itself automatically.
05-10-2020 10:27 AM
05-10-2020 11:51 AM - edited 05-10-2020 11:54 AM
Windows Firewall and/or 3rd party anti-virus can also interfere with connectivity. John's suggestions is certainly plausible as well.
~CarePaks Are Worth It
05-10-2020 10:31 AM
05-10-2020 10:37 AM
05-10-2020 10:46 AM
05-10-2020 11:03 AM
05-10-2020 11:08 AM
