05-07-2025
06:15 PM
06:16 PM
SamanthaW
I am trying to get a MFC (ImageCLASS MF656Cdw) set up on multiple computers through Microsoft Intune. I don't have availability to be able to install the software manually on each computer as needed, so I have scripts set up to install the printers.
With other devices I can do a silent install in the background so there isn't any user interaction - the fact that the install executables on here all require Admin access means I can't just have the files download and let users install as needed.
I can get the Printer driver installed using pnputil, I can also get the scanner driver installed, but I can't get the actual software needed to install. I've tried using "/silent", "/s", "/quiet", and "/qn" arguments but they all bring up the normal UI for an interactive install.
I looked up some other information and found there are silent install instructions for ImageRunner, but not for the MF Scan utility.
Is there any way to do a silent or non-interactive install for the scan utility, or will I need to manually add it on every computer that needs it?
05-07-2025 09:33 PM
You've already tried all of the command line switches I would recommend.
Consider reaching out to Canon Support. They can tell you if the program can be installed silently with a switch. I do not believe it's documented anywhere.
I doubt a GPO would work since you can't get it to work on your own. Let us know what you find out.
07-26-2025 04:15 AM
To silently install MF Scan Utility for imageCLASS MF656Cdw use the installer with a command like:
setup.exe /S /v"/qn"
This runs the setup quietly without user interaction.
