07-26-2025
04:18 PM
04:20 PM
07-26-2025 08:14 PM - edited 07-26-2025 08:15 PM
The TR4722 supports a 2.4Ghz wireless broadcast that uses WPA2 encryption. Please confirm your network meets these requirements.
If you have a dual or tri-band router it might help if you give each broadcast a unique name. You can also try temporarily disabling the other networks while connecting to the 2.4Ghz broadcast, then re-enable them once a successful connection is made.
