05-02-2022 11:25 PM
I haven't used my scanner for years and just made usb connection to my imac turned on scanner and doesn't show. It's not on my devices list. I earlier contacted Canon to download a patch and it said there was no patch for Catalina 0S. To try to use without a patch. Need to connect my scanner to get work done.
05-02-2022 11:31 PM
this is cxfo. I meant to say that I tried to download a driver and Canon couldn't find one for Catalina OS.
05-02-2022 11:43 PM
this is cxfo. a reply to another canoscan 9000f issue seems to apply to my post. Catalina driver is not accepted by Mac's Monterey 12 OS. So I'll try to find another solution. CXFO
05-05-2022 08:54 AM
Hi, cxfo!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
05-05-2022 09:15 AM
If the scanner is no longer support by a Canon driver you could look into using VueScan by Hamrick Software.
I am able to use a Minolta scanner that was last supported with Windows XP on my Windows 10 computer using VueScan.
