03-20-2026 07:51 PM
Hi everyone,
I'm hoping someone in the community here might have experienced a same issue and can help!
I have been trying to connect CanoScan LiDE 300 scanner to my laptop ASUS Zenbook A14 all day. My laptop runs on ARM driver, and it seems like this prevents me from downloading the scanner's driver and software to be installed on my laptop.
And then...somehow I got the scanner to show up under my Printer & Scanner device and was able to scan using Window Scan App but I mistakenly pressed the "remove" button manually under device. Now I cannot get the scanner connected back. My laptop does not recognize the scanner, even when the USB is connected.
If anyone has any experience with this, please let me know!
With appreciation,
Shasha
03-24-2026 02:12 PM
Hi Shasha! Thanks for contributing to the community. I see that you need to add your LiDE 300 to your computer after accidentally removing it.
Since your computer is using an ARM-based processor, you will not be able to install the scanner driver or software that is designed for computers that have Intel and AMD-based processors. You can try adding the printer to your computer's list of printers and scanners. How you do that depends on the version of Windows installed on your computer.
If your computer is running the latest version (Windows 11), here are the steps that you can follow:
If you are unable to add the scanner using these instructions, please check the following:
You can also try restarting your computer while the scanner is connected to it. If your computer says that there are Windows updates available, we recommend that you update your computer during the restart. If turning the computer off and on does not help, please reply to this post with answers to the following questions:
Please feel free to attach a screenshot of the app you are using.
I hope this information helps. Thanks again.
