08-22-2022 06:41 PM
One computer "upgraded" to Windows 11, and another new Windows 11 computer. I swear I have scanned on both since the change to W11. Since the computers did not have the drivers or app installed I did that. Capture On Touch V4 Pro. As of a couple of days ago when I hit Scan, and the power was on, get the message "Scanner is not ready. (Power may have been cycled.) Try operation again. (-4400) Hitting OK gets the same message back over and over. Turning off the power will allow you to clear the error message. Now I find I do not even need to have the app running to get the error message if I turn on the power to the unit.
09-27-2022 03:58 PM
Thanks for the tips, and I will try the Allow computer to turn off the device as well as the Compatibility mode. I have verified the registry and yes restarted, and now currently disabled the WIA service. Done everything else, so far, and yes the disabling of the WIA service works, but not a good answer as it may be needed at some point.
10-22-2022 11:41 AM
So we are now about a month out since I applied this "fix." It still works!!
I hope everyone else that has had this problem gets the same results.
05-10-2023 11:03 PM
This is a firmware bug for Canon Scanners. To temporarily fix this issue we need to set the date and time backwards to be able to scan again.
05-10-2023 11:05 PM
Hi ArthurJ
Your above solutions didn't work. What I found out was setting the date and time backwards fixed the problem. I think this is a firmware issue with these products. I'm currently using DR-C240 scanner.
05-10-2023 11:08 PM
To everyone experiencing this issue just change your current date and time backwards to be able to temporarily use the scanner.
