CaptureOnTouch V4 Index File
marnett53
Is there any way to configure CaptureOnTouch Index file to emulate the Capture Perfect 3.1 barcode log file configuration?
The CaputureOnTouch Index file creation
1. Only allows "Overwrite" existing file or "Add a serial number" to the existing file and create a new file.
2. Creates a CSV file with all selected data elements in one column with comma separator and quotation marks.
Capture Perfect 3.1 would append data to the existing barcode log file with each batch scanned and it saved the Filename, page number and barcode value in separate columns in the CSV file.
2 REPLIES 2
Moderator
Moderator
Hi, marnett53!
So that the Community can help you better, we need to know exactly which Canon product you're using, along with which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Hi Danny,
I am using a DR-G2110 Scanner, with CaptureOnTouch v4 Pro software in a Windows 10 computer
I would like:
1. CaptureOnTouch to "append" data to an existing Index file instead of overwriting or creating a new file
2. Create the Index file in a CSV format where each data element is in a separate column
