Capture Perfect for Windows 11
Harminder
Hey Cannon group, was wondering if Capture Perfect software has an update to work with Windows 11? We have been using Capture Perfect 3.1 with windows 10 and has worked perfectly but cannot get it to work with Win11. This will be used with a fujitsu FI-590 Scanner. Thanks
2 REPLIES 2
An upgrade for CapturePerfect 3.1 is available.  You could try downloads for the imageFormula DR-M140 or DM-M160.  The update specifically addresses a behavior where using editing functions can cause data loss.  It has nothing to do with W11 compatibility.
Canon Support | imageFORMULA CapturePerfect 3.1 for the DR-M140 and DR-M160 | Canon U.S.A., Inc.
The CP software is designed to work with Canon products.  If it works with a Fujitsu scanner this is just a coincidence.  Using the software with other devices is not officially supported.
Thanks Ric. Was surprised to see it actually worked with Fujitsu. Any Ideas on the software working with Windows 11?
