Canon imageFORMULA RS40 not working with Mac OS 15.1.1
ChrisScanner
Application installs with no issues but when attempting to open it says that CaptureOnTouch is damaged and cannot be opened.  I see that there are no drivers for Mac OS v15.  Can we expect updated drivers soon or any work around?
#imageFORMULA RS40
3 REPLIES 3
RLRX
I'm having the same problem. I can at least get the app to partially work but it is finicky and crashes often with single-sheet feed items. Need a fix NOW as tax season is approaching and that's the whole reason for this scanner!
ArthurJ
Please click the link below and download/install the Mac setup file listed
https://soft.canon-elec.co.jp/ims/rs40/en/
Once the scanner is installed, you can download the CaptureOnTouch updated software from the link below;
https://www.usa.canon.com/support/p/imageformula-rs40-photo-and-document-scanner
If the issue persists, we will have to recommend that you contact our support team at 1-800-423-2366, Monday - Friday, 8:00 AM - 6:00 PM EST (excluding holidays).
TouchOfClass
Same problem. Brand new ImageFORMULA RS40. Running MacOS Sequoia 15.3. Successfully installed CaptureOnTouch 4.15.24.1223.
Error: Cannot use driver
