12-21-2017 01:03 AM
Hi There,
We have a user who uses a P-215 II scanner. He uses with auto mode off, so that he could install and use the desktop application for the respective scanner.
However, all of a sudden the scanner stopped working an throws up an error saying no scanner found. Upon removing the scanner cable and reconnecting it with auto mode on works perfectly. So, I figured this could be due to the drivers and it was indeed showing up that the dirvers aren't taken even though it is already installed and has been working.
So I did a complete windows update, ininstalled the software, drivers... etc and reinstalled it again with no success. Device manager still shows that it's not picked up the drivers. I have tried both the USB ports with no luck. So I tried it on a different PC and it was all working fine.
Now the question is how can completely delete the drivers and reinstall it, and make it work?
12-21-2017 10:04 AM
Hi, ahr_helpdesk!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
02-16-2018 12:11 PM
Hello,
I am having the exact same problem with these Cannon scanners P215ii I am using windows 10 64bit and using the most current driver that you have showing on the website (215II_DRIT_V10SP4)
we have several users that use the same computer with different login profiles and for some reason the scanner will work for 1 person but if that person logs off and i have another employee log in witht their own profile the scanner is not recognized.
the orginal person logged in comes back logs in with her profile and everythig is fine.
The error message the other users get is "Can't locate device; check cable and power (-4536)
So i know scanner works fine. it is set to OFF but if i set to ON it works fine for everyone. hope i can get some help on this matter thanks
04-02-2018 10:10 AM
I am having a similar problem. We have numerous P-215 scanners. We have recently upgraded several laptops from WIndows 7 to Windows 10. One every one of them, the scanner driver randomly "disappears" and the scanner will not connect. The only solution is to constantly reinstall the driver, after which it will work for a few days before it disappears again. I have contacted Canon about the issue, and their response is " We don't know anything about it". On several of the laptops, we have replaced the Canon with a ScanSnap scanner and they work fine, so the problem is with Canon, not Windows 10.
05-11-2018 02:09 PM
02-13-2019 10:53 AM
Was there ever a resolution to this problem? I am still not able to use the P215ii scanner with my windows 10 computer.
02-13-2019 02:33 PM
Hi bklein.
So that we can best assist you, what is the exact error that you receive when scanning from the P-215 II?
I look forward to your reply. If you need immediate assistance, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
02-13-2019 02:35 PM
I get the "scanner cannot be found", Check power and cables error. I am not able to get it to scan.
03-06-2019 04:47 PM - edited 03-06-2019 04:53 PM
Patrice and Danny,
In reviewing the thread, we all have the same issue on Windows 10. From my history in working in PC tech support, simply the TWAIN driver is not reaching the apps on Windows 10 64bit. in my instance, it worked once on a new PC, I uplugged it and plugged it back in the next day and the WIndows 10 64 bit system applications would not see it again, but instead sees it as a a FAT drive.
I could post you the error message from the applications I am using but they are not going to be useful because they are non-Canon and application specific. For example, what is a GIMP dialog going to tell you except when you use the GIMP dialog to pick a TWAIN source, it finds none.
To reiterate, the scanner is detected by the system as Storage Disk, not a Scanner. Applications on my Windows 10 64bit PC will not see the scanner. Yes I (re)installed a new drivers that I downloaded from your site yesterday.
Please advise
04-10-2019 03:50 PM
Hello,
I have the same issue.
Could it be due to some Windows Update? I am also running Windows 10 64 bits. I have done some updates yesterday, and it seems my scanner is not working since... yesterday.
The other problem is that Windows is so **bleep**y these days that I do not even understand how to uninstall some updates to test that...
Regards,
Nicolas
