01-29-2022 09:35 PM
I have loved my R40 scanner, but now it won't work. I use the Canon-supplied software, both the driver and the CaptureOnTouch software. Recently, when I've tried to use it, I get "An error has occurred with the TWAIN driver. [Error: 80FF0001]" and that's it.
I've tried re-installing the driver. I've tried uninstalling it and re-installing it. I've tried uninstalling all the Canon software and re-installing the whole software package. Nothing has made it work. Someone, please help! Thank you.
05-09-2022 09:59 AM
Thanks man,
this really helped me out!
I first was thinking about a windows update, as this was the last thing which had changed on the PC.
But as this now poped up a second time and the update is still blocked, the deactivation of the WIA service worked for me.
Thanks a lot for your inverstigation. I also opened a remedy ticket @ Canon Germany regarding this issue.
03-04-2022 02:02 PM
I called tech support yesterday, got right in, the rep gave me a procedure that has worked for me so far:
1. turn on the scanner
dont bother to un-install/re-install the driver.
2 restart computer.
I did this and the issue was no more (for now)
for the record running win11 pro
03-04-2022 02:30 PM
God; but notice that this is consistent with all other reports, that after a reboot, it works fine for a few days...
Wait & see.
03-04-2022 08:11 PM
Yes. Yes we shall.
03-07-2022 10:05 AM
Hello, CANON! Is anyone there doing anything? Are you going to come out with a solution? We all spent good money on your scanner, and it's not working. Please give us an update.
03-13-2022 01:29 PM
I'm in the same boat as everyone else that has posted. Tried everything listed here and have had to just restart the WIN 11 computer every time I want to Scan. That works, but it certainly is a lousy way for a company to respond to a consistent problem with their product. . . . The companies that hire me to evaluate products before purchasing, will be surprised when I report that Canon is not responding to this issue.
05-18-2022 05:52 AM
Hey together,
did you tried to deactivate the WIA service, as mentioned before?
For me this has helped in all of my problems, even with other scanner models like DR-M160, DR-G2090.
I also have escalated this to Canon Germany, they are aware of this issue and are in contact with Canon Europe regarding this. As soon I have more information's, I'll let you know.
Cheers
Daniel
05-22-2022 09:56 PM
checked the services currently running on my system, WIA is not listed in services loaded
05-22-2022 08:53 PM
Cannon pushed out an updated driver last month. the problem persists.
05-22-2022 08:56 PM
Yup. I saw that update and thought, "Oh, good! Finally!" I downloaded it from Canon, installed it, and still had problems.
09-05-2022 04:27 AM
I am having this same problem, and none of the posted solutions have fixed it.
