04-07-2024
09:43 PM
10:50 AM
I just bought and installed a LiDE 400 Scanner. The autoscan button worked fine for about 30 scans and then even when I pushed that button, it keeps giving me pdfs instead. I tried unplugging, switching the port on my computer, rebooting my computer, and reloading the installation and nothing has helped. Is this fixable or do I need to return the scanner?
04-13-2024 09:03 PM
I have the exact same problem. I have scanned thousands of photos but every so often the Auto Scan button only produces PDFs. Today, after scanning many photos successfully, I now can't get anything but PDFs.
04-14-2024 08:31 PM
Sorry to hear you are also having this problem. I returned the one I initially bought and have just received a new one. Will see if I have the same problem with the second one!
04-15-2024 12:36 AM
Hi there,
One way around it that I found is using the Send button as opposed to the auto scan. However to ensure if doesn't use OneDrive storage you have to go to your settings in the IJ Scan Utility and change the "send method" to "None (send manually)" and set a specific folder on your computer for it to save. Works like a charm for me; I am able to save all of them as JPG.
10-13-2024 07:47 AM
Thank You @Neptune_Comics!
I registered here just to say that this helped me a lot! I was frustrated about need of convert hundreds of pdfs to jpegs, and this I believe doesn't add quality.
