10-04-2023 08:50 PM
Hello,
I need to install CanoScan LiDE 220 driver on Windows but without connecting the device.
I tried to run the installation file, sc68-win-lide220-1_02-ea33_3.exe, downloaded from the Canon site, but it won't let me install the driver until the device is detected.
Your input will be greatly appreciated.
10-05-2023 05:09 AM
This is not possible. The device must be present to set up the interface for communication.
10-05-2023 12:38 PM
The driver can be installed without the device connected using PnPUtil.exe command as long as the driver.inf is provided.
https://learn.microsoft.com/en-us/windows-hardware/drivers/devtest/pnputil-command-syntax
I can find the installation software from Canons support portal but not the driver files. I wonder if Canon can provide just the drivers only.
10-05-2023 01:10 PM
This is not supported and hence no documentation for .inf extraction, push or silent install exists.
You can unpack the .msi or .exe using a utility or command line switches. 7 zip might even work.
Once again I'll mention this is not supported, but you are welcome to experiment on your own.
