CanoScan 9950F Windows 7 Drivers Needed
def2251
Hello, I use the 9950F flatbed scanner and I had to change out computers. The one that I will be using is a Windows7 OS and I have lost my install disc. I tried the downloads that Canon offers, but they did not work. I tried contacting Canon, but that did not work as the scanner is no longer supported. So I am hoping that someone out there in the Canon world has a disc that they are not using or that someone is able to make a copy for me so that I can use my scanner. Sadly at this time, I am unable to afford a new one, so this is pretty much my last act of desperation!! Any help or suggestions would be greatly appreciated.
Thank you, Dwayne
3 REPLIES 3
jrhoffman75
If no one can help you with your request, VueScan by Hamrick Software has drivers for most Canon (and other) scanners.
I use their software with a Minolta scanner that was last support on Windows XP by the manufacturer.
The 9950F is 22 years old
Windows 7 drivers are available for the 9950F here:
Canon Support for CanoScan 9950F | Canon U.S.A., Inc.
You said "they didn't work for you".  This might indicate a problem with your operating system.  Microsoft no longer supports Windows 7.  Like the printer, it too is end of life.
 A fellow user @jrhoffman75 has provided an alternative.  VueScan.
If neither of this options work for you, it might be time to consider a replacement.  Canon has an upgrade program.
A specialist can be reached at 866-443-8002 Monday through Friday from 9am to 9pm (ET), excluding holidays.
normadel
I agree that your problem may be Windows 7. I'm not a shill for Microsoft. You really need to get off 7. It is now way out of the mainstream supportwise in many ways.
I have a CanoScan 8800F that was not "supported" past Windows 8.1.  I was on Windows 10 when I acquired it. I tried the Win 8.1  driver and it worked perfectly. Now I am on Windows 11, and the 8.1 driver also works perfectly.
